I am facing problem in order to convert the project in to re framework
YT channel opertions.zip (61.2 KB)
in this the main problem that i am facing is we create a new sheet for every input and how do we upload every sheet after every iteration.
or can we use re framework and convert the existing project without using orchestrator
it will be very help full - convert the file into re framework.
cheers.
yt input.xlsx (17.6 KB)
Hi @Adithyeshwar_goud ,
check your flow and change each step corresponding to each module of the frame work,
regards,
