Is it possible to call API as run https request for upload a file using POST method with the body of request is multipart/form data. Please give me an example. Thanks in advance!
@ADimmitrova
welcome to the forum
it depends on the API and which payload is how expected. Can you share some more details with us?
we would suggest the following:
- test the call with Postman
- then transfer / build it within UiPath HTTP Request
feel free to share the curl with us (redact sensitive data)
Especially with multipart / attachments when the API expects it under a certain constraint / key we encountered some limitations by the implementation of the HTTP Request. In such case we can handle it by custom code and using the HttpClient class
maybe this converter helps for the start
Thanks Peter! It works ok with Postman. I will try to use a code with HttpClient Class.
