HTTP Request - Body as a parameter issue!
hi there, i am trying to set up twillio for whatsapp, if i put in the body using as paramter, when previlling it, it is able to sent the whatsapp message, but the error will also appear, how can i configure it
Kindly share more details on the steps and error
hi, if i use body as a parameter and doing preview, it will sent over. but when i input it into the priorities - body field, it failed
Is there a reason you need to use the HTTP Request activity, instead of the Twilio Integration Service activities?
Twilio Activities Package:
Hello @Teck_Hwee_Goh
Have you tried using the Body argument shown under properties?
Regards
Soren
hi yes i have, the following was put into the body.however the error message will appear. if it put in as a parameter body then it will be the first error message, however when previewing it, it will sent out the whatsapp message “To=whatsapp%3A%2B6591234567&From=whatsapp%3A%2B14155238886&Body=Hello%21%20This%20is%20a%20test%20message%20from%20UiPath.”
hi, i have tried it, doesn’t work and also i’m trying to sent whatsapp message, not sms
see the above successfully sent but only in preview and i can’t run the activity because it is using body as a parameter
What happens when you change the parameter from “Body” to "Message?
this appears then, it only recognize “body” as the parameter
