AryanS
(Aryan Singh)
January 11, 2021, 10:55am
1
HI @ All
I am trying to use invoke code activity to copy the sheet and give it a different name i.e. Input Sheet for the input and output sheet for the output.
And merge the cells with similar values in a single column.
Can anyone help me regarding this?
Thanks in advance.
@Palaniyappan Can you help me?
moenk
(Thomas Meier)
January 11, 2021, 11:59am
3
What you think cells with similar values are?
Do you mean with Invoke VBA Script?
I would do something like this:
Sub Macro1()
'Copy input sheet
Sheets(1).Copy After:=Sheets(1)
Sheets(2).Select
ActiveSheet.Range("A1:C100").RemoveDuplicates Columns:=Array(1,2), Header:=xlYes
Of course you would have to adapt the range for your specific excel input. See Range.RemoveDuplicates method (Excel) | Microsoft Learn .
Another option is to use the in-built UiPath activities. I think that would be easier?
AryanS
(Aryan Singh)
January 11, 2021, 12:37pm
6
@mari.svh
Thanks.
What if i want to merge the cells with same values in one column?
I mean, if the entries are always sorted like your illustration you could use UiPath and do:
> Use the Read Range Activity to get the Input sheet as a DataTable dt_input.
> Initialize an empty dt_output
> Initialize an empty DataRow Object called previous_row
> For Each Row in dt_input:
> If Row == previous_row:
> previous_row = row
> continue
> Else:
> add row to dt_output
> previous_row = Row
This VBScript removes all duplicates from column 1 and 2 (see Range.RemoveDuplicates method (Excel) | Microsoft Learn ). So if you want to merge the cells with the same values in column C you would write
ActiveSheet.Range(“A1:C100”).RemoveDuplicates Columns:=Array(3), Header:=xlYes
Kindly let know if any further clarification required
Have a great day
Cheers @AryanS
