Hi Team,
I have one use case to write a column value in particular cell based on row index value.
Please let me know how can I achieve the same.
Thanks,
Riya
Hi Team,
Thanks,
Riya
Hi @Riya1 ,
For example if you want to insert data in column A, then keep it in a loop and assign counter =counter+1. Write the cell like this A + counter.tostring. It will works as you expected.
Pavan Kumar
Hi Riya,
You can use Assign activity-
To : Datatablename(rowIndex)(columnIndex)
Value : The value to be entered
For Example,
If Cities Datatable values are
“Chennai”,“Bengaluru”,“Bombay” and you want to update Bengaluru as Delhi which is in 2nd row, you have to use Cities(1)(0)=Delhi
Hope this solution works for you!!
Hi @pavan_kumar5 ,
Could you please share the sample xaml,if possible.
Thanks in advance.
Thanks,
Riya
Hi Riya,
Use this syntax to get column index : datatablename.Columns(“[ColumnName]”).Ordinal
Hope this will help you
