HOW TO START AUTOMATION USING EXCEL
can help me using workflow not from developer?
@Nur_Amin
the workbook activities will be in developer option only so please mark the developer option as true and then you can use the developer options.
Regards
@Nur_Amin
if you don’t want to use the developer options then please use the below workflow
for your reference I have attached the xaml below
Main.xaml (14.3 KB)
Hope it helps!!
hi i already tick the deveper but when i run it appear error
@Nur_Amin
can we connect?
regards
@Nur_Amin
try opening the xaml again
Main.xaml (14.3 KB)
Regards
how to connect? let me know
@Nur_Amin
I have shared a link to you personally please connect through that.
Regards
hi i have try to go into the link but there is something that block i thing becasue this is my company laptop
@Nur_Amin
Have you tried this process?
Main.xaml (9.6 KB)
Hope it helps!!
i laready try the things is when i run it stuck. how ya? for the destination do i need to insert new sheet first?
@Nur_Amin
not needed of inserting a new sheet first and can you please try opening the xaml now please.
Regards
hi i cannit open the xaml
@Nur_Amin
please try this its working
Book1 StudioX.zip (259.6 KB)
REGARDS
@Nur_Amin
have tried the uploaded zip file?
Regards
Hi, anyone can help me on this?
