Hi all, i have one question, how i can start an Process… for example an archive in desktop?
No. This was just example for PS script. For “oneliners” you can use only Invoke PowerShell
activity.
Hi @GabrielMoreno,
I think a simple command to archive would be :
Compress-Archive -Path C:\Desktop -DestinationPath C:\Archives\Draft
However in case you want to pass the folder path as an parameter rather than hard coding, you can follow the integration steps mentioned above. You need not read the script from file, you can store it in variable or directly pass it to Invoke Powershell
activity as mentioned by @Pablito .
