Hello all,
Can anyone know how to split the string using regex where whitespace as a delimiter?
Input string:
xxx 0190 a b c
Expected output:
xxx
0190
a b c
Hello all,
Input string:
xxx 0190 a b c
Expected output:
xxx
0190
a b c
Can you share if there is a rule not to split “a b c” part to a, b and c?
No @Yoichi . There is no rule. Main issue is I need to split string based on whitespace using regular expression.
then above mention is not conform with expected output:
a b c
as here the space for splitting was not applied.
We agree with:
Assign -> Input = "xxx 0190 a b c"
Assign -> Output = System.Text.RegularExpressions.Regex.Matches(Input.ToString, "[A-Za-z0-9]+")
Message Box -> String.Join(Environment.NewLine, Output.Cast(Of Match)().Select(Function(m) m.Value.Trim()))
Input is of DataType System.String. Output is of DataType System.Collections.Generic.IEnumerable(System.Text.RegularExpressions.Match)
Regards
I have added a b c its because some times the string looks like “firstname middlename last name” . so i have to capture all the strings(firstname, middlename, last name)
Input:-
Output:-
Xaml file:-
Main.xaml (8.1 KB)
If this works for you, please mark it as a solution, so others can refer the same. ![]()
Thanks
so it is not a consequent split on space.
In such cases we would check more on reliable patterns and can use techniques of inserting delimiters like:
so we can split on | afterwards and would also trim the splits
Hi @ppr . Thanks. Can you explain more in detail. if possible, can you post the code for reference.
Have a look at this series:
And feel free to break it down in smaller sub parts
Thanks @ppr . Its working.
Perfect, so the topic can be closed
Forum FAQ - How to mark a post as a solution - News / Tutorials - UiPath Community Forum
