How to pass json body for post api call
Hey
Im new to api calls & im stuck at a point where I need to perform a Post API call with json body as input
so after providing the endpoint url & I’m supposed to pass the entire json string in its body right ?
(let me know if I’m doing anything wrong)
But in uipath the Json is not taking directly & showing me this following error
Please help me by providing me the solution
@Jiban_Kumar_Das_TcM
Hi @Jiban_Kumar_Das_TcM ,
I am sending you a sample workflow for your reference which might help you.
PassingJsonStringFromAssign.zip (1.9 KB)
The main problem is that, the string needs to be in a single line while you are assigning it to a variable, it can’t be as the body we send in postman.
Thanks & Regards,
Shubham Dutta
Check this example Making web API call, Method not found - #7 by marian.platonov
understood, thanks for the input
But 2nd doubt will be the body currently exists in a cell value
then i can manipulate the strings to bring all the values into a single line ??
Hey
now my doubt will be, the body currently exists in a cell value( cannt hardcode it as these value changes & are always updated in that excel file as a cell value soo
how i can manipulate the strings to bring all the values into a single line ??
Check here CSV to JSON conversion
Afte scrolling through so many threads for this small item, I guess UiPath must do something on this common issue. So far easiest option I found is to replace " with “” in your JSON which is passed as a string in HTTP request.
Hi @tejaskumar.darji,
Please see my post here:
We’re trying to make things better as quickly as possible. More improvements are coming as well :slight_smile:
