while joining two tables with identity column username it should allow null values as shown in output screenshot
Do you need in particular only LINQ query?
Because we already have one activity which does your requirement. Please have a look -
Karthik Byggari
Iam using 2018.2.6 only Join Datatable activity is missing so iam trying with linq. I have tried updating uipath.core.Activities also but no use. Kindly help must be helpful.
@Aravinthan hi, first build datatable with column using(build datatable activity) and assign that table with value
(From a In DT1.Select()
Join b In DT2.Select()
On a(“Name”).ToString Equals b(“Name”).ToString
Select dt5.LoadDataRow (New Object() {
a.Field(Of String)(“Name”),
a.Field(Of String)(“City”),
a.Field(Of String)(“Country”),
b.Field(Of Double)(“ProjectID”)},False)).CopyToDataTable()
HI!.As YOu can see in Datatable 1 and Datatable2 syntax of word “Srini” (“srini”) is different.
Is it possible to use LINQ for joining that kind of data’s ???
Or using als condition another keyword than EQUALS?
If you have another example - i will be very appreciate.
Thank you !
@Maryna_Shubna
Handling such minor differences e.g. can be done with toUpper
e.g. On a(“Name”).ToString.toUpper Equals b(“Name”).ToString.toUpper
Join and especially the ON clause has defined some strict construct (e.g. leftside EQUALS rightside)
In some cases a cartesian Product can be used, but has also Cons and Pros
Is it possible to make these Manipulations ( toUpper etc) within JoinDatatable activity???
p.s. by example i would like to make join 2 tables where Name in Table1 is substr(1,10) ( by example) of Name in table 2. Something like "MarynaShubna_the_Queen " and “MarynaShubna”.
Thank you in Advance
toUpper as mentioned is possible
Your case with the name should be possible as well
Someting like
On a(“Name”).ToString.trim.substr(1,10) Equals b(“Name”).ToString.trim
… rest of statement
I didnt count the length of the name, substring start index is 0 etc. so statement is for showcasing only
YES ! I Understand YOU ! Thank you VERY much!!!
You’re welcome - Happy automation ![]()
