How to get connected to Power BI using UiPath Studio
I need to fetch the data from Power BI tool often. How can I get connected to Power BI query and get the data using Studio?
please prefer to this link https://forum.uipath.com/t/how-to-create-charts-in-powerbi-desktop-using-uipath-studio
I don’t think that matches to what I am looking for. Or are you trying to say there is no way to get connected to Power Bi using Studio?
I am trying to get connected to Power BI(Desktop or Web) and refresh the relevant data there and download the excel report.
Hi @Krithi1,
To connect to Power BI using UiPath Studio, you can use the “Power BI Activities” package provided by UiPath. This package provides a set of activities that allow you to interact with Power BI, including refreshing data and downloading reports.
Here are the steps to connect to Power BI and download a report:
Once you have set up these activities, you can run the UiPath workflow to refresh the Power BI report and download the updated data in Excel format.
Power bi pulls the data from some db and it would be ideal to pull the data feom there…but if you are still looking for power bi app only then try with ui automation of manually clicking on the reports and clicking export from menu or by right clicking on the reports…
