How to filter datatable without using filter datatable activity?
@niteshbutola5 - please ping the query that you are using in assign activity.
hi Vijay pls hv a look on the attachments below
strData1.xlsx (11.4 KB)
DataTableAutomation2.xaml (11.8 KB)
ya its from same column
DTs.Select(“Item = ‘Pencil’ and Item=‘Pen’”).CopyToDataTable
ok ill try with diff columns.
anyway tq vijay
@niteshbutola5 - I am glad that it helped you. if the issue solved please mark this thread as solved with suitable post. so that other people will get benefit.
Let me know if you need any help on this.
Vijay.
yeah it worked.
thanks a lot.
@niteshbutola5 - Can you please mark this thread as solved. you have to Check the Solution Check box on suitable solution post. then only it will mark as solution.
Vijay.
don’t know where is solution check box
pls let me know
