How to enable Process Mining in Free Pro Trial Automation Cloud
I have just registered and logged into the free trial. I have selected all available Services in the Admin console but cannot see the Process Mining option in the left hand menu. I can see from other posts you can install in Azure but is there no option to enable in Automation Cloud?
Process mining is directed towards enterprise users and it’s not there in community edition or free trial
You may try it - more details here: Process Mining Tool - Business Process Mining | UiPath
Cheers @karlv
This service needs to be enabled from the admin panel ( see below link) and you are using community edition then this option is not available in community edition.
https://docs.uipath.com/process-mining/automation-cloud/latest/user-guide/pm-enabling-the-service-in-automation-cloud
Is it possible to try the Enterprise Edition as a trial?
Yes, UiPath offers a trial version of its Enterprise Edition but even if you started trial version you will not see process mining… for process mining you need an licence.
