Hi everyone,
I would like to check a project for arguments mismatch and/or not connected arguments values for all usages of ‘Invoke Workflow File’ activity. Normally I would say the Workflow Analyzer should help here, but I’m not getting any errors/warning having situation like that:
I check the workflow analyzer rule sets, there is not a rule available to check for empty Value inside workflow argument. In this case, you have to create a custom rule for workflow analyzer.
As @GreenTea rightly pointed out. This rule does not exist in the default workflow analyser rule set.
If you do have to make a custom rule for your organization you will have to invest some time to make them in visual studio and also test them in UiPath. Here is the walkthrough on how to build custom rules : Building Custom Rules
That said, you and your developers can actually avoid this by clearly defining a development standard and each developer owns their share of code and ensures that all invoke workflow activities are given special care with respect to their in / out arguments.
The time it might take to build and test custom analyser rules may be not so worthwhile if your developers are already proactive and now know what to look out for while developing.
Hi @jeevith,
I think it’s certainly worth it to build that rule(s). I’d say the whole point of static analysis tools (like workflow analyzer) is to catch this type of mistakes and speed up development. No one likes tedious tasks like checking every workflow in the project. Even the best team with the greatest standards sometimes makes mistakes and we better catch them before going to production.
@loginerror I think these rules is a must have and they should be standard rules. Any chance it will be put on a wish list? (Sorry to mention you personally, but I’m not sure how to mention UiPath Team).
I am also missing a validation on deleted/removed arguments.
Scenario: You have a workflow which is invoked multiple times and you remove an argument from it.
You have to find manually (ofc with the find reference) all stages, where this workflow was invoked to update the arguments. If you miss one, no validation rule says “stop”, but an exception on run.
