I want to save extracted data into excel but facing “cannot covert system.data.dataset to system.data.datatable” error
DataSet can has multiple datatables. If there is single datatable in it, the following will work.
dt = ds.Tables(0)
If we can know name of the datatable, the following also works.
dt = ds.Tables("TableName")
Note: ds is DataSet, dt is DataTable.
@raju_alakuntla The extracted data will be in a datset. You have to get each table from the data set then you can write that into an excel
Please find the below workflow your scenario
Dataset.zip (2.4 KB)
I could able to convert it but its overwriting data in excel.please give some solution
thanks. but data is overwriting into one cell everytime. please give me solution
Can you share your input and expected output, workflow etc?
I am extracting handwritten data using document understading and intelligent Ocr and storing in excel for 4-5 files.
is it the problem with loop or anyother
@raju_alakuntla Did you go through the workflow that I have shared with you ?
Also, can you share the screenshots of your code for writing data into excel
Have you gotten a solution for this? I am having the same issue.
