Hi Team,
I wanted to convert datatable to PDF without using word activity as word is not installed on robot server. Could someone please help on it.
Thanks,
Nancy
Hi Team,
Thanks,
Nancy
Hi @Anil_G
I am extracting some column values from excel to datatable and need to copy the datatable to pdf document for mail merge activities.
Should I need to convert datatable to excel again and then save as PDF.
Thanks,
Hi @Nancy29
Try this
Yes you need to convert again to different excel because save excel as pdf activity converts total excel as pdf if you dont want to convert all sheets to pdf then my suggestion is create new excel and convert to pdf
Hi @Nancy29
No need to convert the datatable to excel, If the datatable is in the excel then you can use the excel activities to save the excel as pdf, for that you can use the Save Excel File As PDF activity.
 → Use the Use excel file activity and pass the excel file path.
 → Inside Use excel file activity insert the Save excel file as PDF activity. Then give the path of the PDF path where you want to save it as pdf.
Hope it helps!!
Either you can directly delete the column on excel only or can write the datatable to excel and then save as pdf
cheers
Step 1:
Step 2:
Step 3:
Step 4:
cheers!!
Hi @sai_gupta
Export to PDF activity is removed from UiPath Studio, I guess. I couldn’t be able to get the activity.
Thanks
use this instead of export to pdf
System.IO.File.WriteAllText("C:\Path\To\Your\File.pdf", yourTextContent)
cheers…!
Sure. Thankyou for your inputs
Thanks All for your inputs. it helps.
when the solution flag is set to
Can you please share with us a sample of the PDF generated with:
and a screenshot of the used modellings? Thanks
