HOW TO CONNECT TO UNIX SYSTEM USING UIPATH
Hi Team,
@aksh1yadav, @ovi
I want to login to Unix system from windows system and perform basic operation like send some command to command prompt.
Please help me with it.
Thanks and Regards,
ShraddhZJ
Have a look at terminal activities if it works for you. If not you can automate the commands by using send hotkeys atleast.
Thanks,
Rammohan B.
This package (Connect to SSH) may be relevant as well.
https://go.uipath.com/component/connection-to-ssh-server
