I have string variable, which different each time, but it always starts with small letter. Haw can i capitalize first letter ?
Variable.substring(0,1).ToUpper+Variable.substring(1).toLower
@boadriqa
testcapit.Substring(0,1).ToUpper+testcapit.Substring(1).ToLower
What a stupid mistake I’ve made I definitely need some rest) Thanks a lot!
You will not need to do so much. Use Propercase and it should make your string into the required format.
See here:
It works! thanks!!
