Example excel here
I need the result is only row 2-4 or 3-4 or 4-5
Any tips for this? Thanks
Example excel here
Hi @lovepong66.
You just use the range from the 2A:4C.
Hope this will works for you.
Regards
Awais Ali Qamar
Can you try to use Take method and Skip method as the following?
The following return 3-4 because row 2 is skipped by Skip(1) and return 2 rows by Take(2)
dt.AsEnumerable.Skip(1).Take(2).CopyToDataTable()
Details
and
Newtonsoft.Json.JsonConvert.DeserializeObject(Of Newtonsoft.Json.Linq.Jarray)(Newtonsoft.Json.JsonConvert.SerializeObject(dt))
I tested on it but nothing come out. by the way thank you very much for your reply.
