Hi team anyone help me how to kill the mobile connection after execution finished
Hi team, my requirement is once mobile script execution is completed i need to terminate or kill the device for second execution .
can you anyone help me in these scenario,
Thank you in adavance.
Regards
Saikrishna
@Mada_Sai_Krishna
Manually how do you do it?
Did you try with killing whole app?
@Anil_G
Manually it’s not getting any issue but while running the orchestrator screenshots are capturing the previous runs
and tell me how to kill app in that device
