Help with code for flow decision
Hey guys,
Im stuck on wanting this to work(could solve this another way but i kinda want to do it this way).
I’ve got a datarow(in_transactionItem) argument containing 10 columns. Then i’ve got a datatable(in_DT_SignalerDel2) containins 2 rows of numbers.
In the flow decision, i want to check if the datarow column 8 contains any of the numbers in the Datatable. If so the statement is True and it will continue down that path.
So far i’ve got this:
in_TransactionItem(8).tostring.contains(in_DT_SignalerDel2.AsEnumerable().Any(function(r) r(“Col1”).ToString().StartsWith(“2020”)
However the error message says" ) expected". Could anyone just give it a quick check as to what is wrong with the code?
thanks,
T
Hi @thomasb82
Try this
in_DT_SignalerDel2.AsEnumerable().Where(function(r) r(“Col1”).ToString.Contains(in_TransactionItem(8).tostring)).count > 0
This will get rows which are matched and > 0 will check if there are any returned or not
cheers
Works! Thanks!
