hi all ,
i want the dropdown name fetched automatically without selecting dropdown using for each or else if condition is this possible
after that
i would like to select one by one each name in dropdown
@Shubham_Bidwai
From where do these names come? From a different row in the data table or in the same row?
In this case, you could use select multiple items activity
any suggestion or solution after screen shot
from web application
@Shubham_Bidwai
You could save those names in array of strings and pass the array in the multiple items property in the select multiple item activity
in dropdown name can not copy paste
It is possible to retrieve the name of a dropdown menu in UiPath without manually selecting an option from the dropdown. One way to do this is to use the GetAttribute
activity to retrieve the name
attribute of the dropdown element.
You can use a For Each
loop or an If
condition to iterate over multiple dropdown elements and retrieve their names. For example, you could use a For Each
loop to iterate over a list of dropdown elements and retrieve the name of each element.
Keep in mind that you will need to specify the selector for the dropdown element in the GetAttribute
activity to target the correct element. You may also need to use additional activities, such as the Find Element
activity, to locate the dropdown element on the page.
thanks i will try the procedure
hi can you help me with one more problem
i want to add variable in my table which is in send gmail activity i create one table and i want to add the variable value in it
