Hi Guys,
I want to split string, The below is the sting i want to split.
Get this document done - Please finish it before - 4.
Result: Please finish it before - 4
Hi Guys,
Split(“Get this document done - Please finish it before - 4.”,“done -”).Last
you can simply replace text(Get this document done - ) with null.
Str1.Replace("Get this document done - ","")
You can get the value by using String.Replace
Str1 = "Get this document done - Please finish it before - 4."
Str1 = Str1.Replace("Get this document done - ","")
Try the below code
strArr = “Get this document done - Please finish it before - 4.”.Split("-"c)
strVal = string.Join(string.Empty,strArr.Except(new string(){strArr(0)}).ToArray())
Hi All,
Thanks for your response,
Im having this value in datatable row.item(1). im using below expression.
The string i want to split Get this document done - Please finish it before - 4.
Expression im using row.item(1).tostring.split(“-”,c)(1).trim
Result im getting Please finish it before
But i want Please finish it before - 4.
Try this:
row.item(1).tostring.split("-",c)(1).trim+"-"+row.item(1).tostring.split("-",c)(2).trim
Try as below code, assign the split string into a variable strArr
strArr = row.item(1).tostring.Split("-"c)
index was outside the bounds of the array
this is the issue im facing
Try this
variable1=“Get this document done - Please finish it before - 4”
variable1.Substring(Variable1.IndexOf(“-”)+1)
Hi
kindly try with this expression if this input is in variable str_input
str_output = System.Text.RegularExpressions.Regex.Match(str_input.ToString,“(?<=-).*”).ToString.Trim
it worked as well
Cheers @arivazhagan_mathivan
Try this :
row.item(1).tostring().Substring(row.item(1).tostring().IndexOf(“Please”))
