Hi All
Developed one code in my machine and shared the code with business team. They are trying to open that code in their machine but getting Document in valid, Why ?
why i am getting this?
Any guidance would be appreciated.
Thank you!!!
Please refer the below thread
It’s due to project compatibility. You would have developed the workflow in windows compatibility and you’re trying to open it in legacy now.
Try opening in new project with windows compatibility this should not give any error.
Thanks,
Ashok ![]()
Hie @victoryv4569 First check the Studio Legacy are same in the Business Team .
and if they are same try to make Project Dependencies same version with your machine version …
cheers Happy Automation
Hie @victoryv4569 when you open the Studio and start to make a new process there you can see the compatiblity
We can migrate from Legacy to Windows only not vice versa.
To migrate from legacy to Window, right click on the project and click on Convert to Windows
Thanks,
Ashok ![]()
