Here i tried the some prompt i got the output like below text file
And i want to clear statswith ‘’‘JSON and endswith ‘’’. how can achieve using prompt
I used it but getting output as json format only but the thing is I getting text containing ‘’‘json and at last words after extraction ‘’’. Here I don’t want the letters like this where my bot fails
Sorry, I’m not getting your question. Would you be able share screenshots with currently getting and expected?
Thanks,
Ashok ![]()
Ashok
do you understand the issue what iam asking
Sorry, still not getting.
can you see the text at beggining of the file in screen shot where mensioned ‘’'Json right i dont want those letters. how to to do this ashok
Ashok,
Do you understand now?
I think I got it. You are talking about this red highlighted.
If yes, better to remove it from response than telling the GEN AI to remove it. It would be easy through text manipulation like replacing ````json with “”`
Thanks,
Ashok ![]()
Yes! You got it. How to remove iam trying it alot for the prompt but iam failing, can you please help on it ashok
Ashok,
could you please join google meet please iam waiting
Ashok,
Iam waiting for you in call please connect bro
bro,
what bro your are not connecting
