Hi Team,
Even though i indicated the target element using For each UI element, i am getting below error
Hi Team,
Please check whatever you indicate in Use application browser and the uielement you are indicating using for each uielement are referencing the same Webpage.
Click on the indicate option in For each Ui element activity and indicate the Ui element in the browser.
Hope it helps!!
Hi @rlgandu ,
yes i am indicating the same webpage
Can you please share your workflow
It’s a already reported bug. Try upgrading the System package to latest version and then try.
If already on latest package, downgrade by a version and then try.
Thanks,
Ashok ![]()
Hi @ashokkarale ,
After upgrading to latest version issue got resolved. can you please help me with the below as well.
Great! Let’s split this to one issue per thread. Kindly mark my answer solution and create a new thread to get all experts attention to it. Till that I’m analyzing the issue.
Thanks,
Ashok ![]()
Sure @ashokkarale , thank you !!
