Hii everyone
please help me why i am getting this type error how to resolve it
Thanks
Hii everyone
Thanks
@zaid.ahmad , For what use are you using this loop?
To loop a datatable?? then you have to use “for each row in datatable” activity
In the for loop properties you have to change the type argument according to the items you have in the in argument you provided.
Say you provided a list of strings then type argument will be string
Hello @sangeethaneelavannan1 @muhamed_fasil @Anil_G
Actually i was using excel application scope for reading multiple xml file one by one after that i want to read whole sheet of each file and using get workbook sheet activity and then using for each row for getting Sheet name and the data type i kept as a String.
Thanks
Good…but,which for each did you use and what type of variable you passed in the in arguments
You should use for each activity not for each row
i have using For Each and type argument is String
Yes i am Using For Each activity
In the for each what did you give as in argument?
Type argument depends on the in argument you passed
cheers
Get workbook sheet return sheet name as string.inside for each,what Activity you used?
I have passed the String Argument
I have use same as a String
@zaid.ahmad , The output of the get worksheet name should be list of string right?
Can you just confirm me on that? that list of string variable should be passed to " for each " with type argument as string!
Hi @zaid.ahmad the output of get workbook sheet is string but another activity get workbook sheets is there,that return list of string.which one you are using?
yes right i have passed in String
i am using List of String in get workbook sheet What should be use there?
