Extract specific string from below string (using Regular Expression)
Hello everyone,
Below is the string from which I want to extract few strings which is higlighted in bold.
Need 2 solutions.
  1. Want to extract all the strings separately like 1,2,3…
  2. Want to extract all strings in For each loop
Please refer below string
2022-09-27 04:02:43 - Dexter Pax (Additional comments)
template mentioned OPP ID to update.
Δ Net Δ Direct Δ Other Δ Contract
47,868,588 7,454,998 2,484,999 13,881,888 11039259 11083245
85,559,700 45,562,551 15,187,515 24,809,638 11043432
clearly monthly capital charges
2022-09-22 04:35:29 - Dexter Pax (Additional comments)
Hi Team,
You are receiving this email as more information
Requesting you to check and confirm
Note- If you do not reply within 10 days with the additional information needed
Thanks
Team
2022-09-20 06:22:48 - Dexter Pax (Additional comments)
update is 190.374.683,06. thank you!
2022-09-20 02:05:26 - Dexter Pax (Additional comments)
Hi Team,
You are receiving this email as more information is needed
Note: String is dynamic and can contain any number of comments
Thanks,
Rushi
HI @Athawale_Rushikesh
You can try with this expression
System.Text.RegularExpressions.Regex.Match(YourString,"^\b\d{4}-\d{2}-\d{2}\s\d{2}:\d{2}:\d{2}\b.*").Tostring
Regards
Gokul
In For each activity use this expression to get the count
Enumerable.Range(0,System.Text.RegularExpressions.Regex.Matches(YourString,"\b\d{4}-\d{2}-\d{2}\s\d{2}:\d{2}:\d{2}\b.*").Count)
Inside the For each activity
Use Log message to get the Data
System.Text.RegularExpressions.Regex.Matches(YourString,"\b\d{4}-\d{2}-\d{2}\s\d{2}:\d{2}:\d{2}\b.*")(CInt(currentItem))
Check out the XAML file
MatchesRegex1.xaml (6.6 KB)
Regards
Gokul
Hi @Athawale_Rushikesh try this regex pattern:
