Excel automation using for eachcolumn and check if row number 148 has value less than 5
Hello all
In UiPath in a datatable i have a requirement to check for rowno 148 has value greater than 5 or not in each column .
Thanks in advance
Read the excel sheet using read range
then use for each row In data table
take if activity
You can use the DataTable.Rows collection to access rows and columns using indexes. For example: yourDataTable.Rows(147)(columnIndex). The index is 147 because indexes are zero-based.
If the condition is met, you can perform the desired actions.
Hope this helps,
let me know if it works or send me input file so that i give a try
@kambhampati_manisridhar
To find row contains the required value
dt.Row(147).ItemArray.Any(function(x)
cint(x)>5)
Gives you boolean output
To check in any column
To check only one specific column use below syntax
Booloutput=cint(Datatablevar.rows(147).item(“columnname”).ToString)>5
If (dt_Table.Rows(147)(column) > 5)
Hi @kambhampati_manisridhar
For Each column in DataTable.Columns
If DataTable.Rows(147)(column) > 5
// Perform actions (e.g., log the column name)
End If
End For Each
