Could you please help me on how to download reports from Power BI using UI Path studio.
Thanks in Advance!
Thanks in Advance!
Hi @Madhura_PS,
Welcome to the Community!
Well basically you should start from defining what you are doing manually to get those reports and then step-by-step build automation around it. Like go here, then click here, then write something, click save and so on. I’m not sure if PowerBi have any API by which you could do this in simpler way.
