Concatenate values of Column Index1 and Column Index2 values and write in a single line, after following certain operations in Column Index2
Hello everyone :slight_smile: ,
I am facing problem in concatenating values of my two column indexes. There is a fix header for column index1, but not fixed header for column2.
I need to sort column2, round off it, then concatenate the entire result in a single line.
Please find attached the workflow, I am getting the required mapping, but it overwrites the previous value every time, when I am trying to write in a single line.
Output needed in this format- +$3.8 M Price,+$1.4 M Other,+$0 M Acquisition,$-0.9 M Physical,$-6.5 M Mfg
Output getting :smiling_face_with_tear:-
Screenshot 2024-01-10 214455
Mapping.xaml (14.9 KB)
Thankyou in advance :slight_smile:
Hi @Neha_Kumari1
Is this the output you want
Sequence2.xaml (15.8 KB)
Cheers!!
The general building Block
grafik
And enhanced (first Level)
grafik
(From d In DT.AsEnumerable
Let n = CDbl(d(1).ToString.Trim)
Order By n Descending
Let s = String.Format("${0} {1}", n.ToString("N2"), d(0).ToString)
Select v = s).ToArray
grafik
For flattening the Array we can use Strin.Join
For sure we can adapt more and fine tune
E.G. with using
grafik
And
Let s = String.Format("{0} {1}", n.ToString("$+#.#;$-#.#;(0)"), d(0).ToString)
grafik
Hi @lrtetala ,
Thankyou so much for your response :slight_smile:
Yes, I wanted the same way, just one thing I didn’t understand, for some values like +$-0.9, +$-6.5, it has both + and - signs there, even though we have this condition in our workflow ,
If ‘ItemValue.ToString.Contains(“-”)’ , just add $, otherwise add ‘+$’
while in output it shows the correct ones
Could you please help me understand this :blush:
It’s my Bad @Neha_Kumari1
I forgot to add Append Items to Collections activity in else block…Please try below
Sequence2.xaml (17.2 KB)
Cheers!!
Hi @ppr ,
Thankyou so much for your response :blush:
I tried the solution you suggested. I also need to perform a few operations on all the values there, as dividing the value by 1000 then round it to one digit.
I was using this, ‘(Math.Round(ItemValue,1))/1000’ followed by ‘Math.Round(ItemValue,1)’ , so as it comes like +$3.8 M Price,+$1.4 M Other,+$0 M Acquisition,$-0.9 M Physical,$-6.5 M Mfg
how can we apply this to all our values in linq
not complete clear the updated requirement
Are you looking for:
grafik
Let nd = n / 1000
Let s = String.Format("{0} M {1}", nd.ToString("$+0.#;$-0.#;$0"), d(0).ToString)
Also feel free to adapt:
grafik
EDITED: Fixed
grafik
And
grafik
Thankyou so much @lrtetala , for adding this to my knowledge :blush:
It works…
Glad to be helped…If no more questions can you please close this topic…else happy to help @Neha_Kumari1
Yes, this was required, thanks for your clear explanation.
It works…Thanks a lot @ppr :blush:
Perfect, just updated a few minor cosmetics.
So we do feel that the topic can be closed
Forum FAQ - How to mark a post as a solution - News / Tutorials - UiPath Community Forum
Hi @lrtetala, thankyou for asking :slight_smile:
I was trying the solution with one extra column, again dynamic header, it has ‘Item Comments’, which might be there or might not be. If comments are there, I need to add it along. It’s appearing correctly in logs. But I guess it’s not getting added to the Collection. Please suggest…
you could find image and xaml attached
Sequence2.xaml (23.0 KB)
can you share some sample data with this optional Item Comments column
When a different output is expexcted also share the epected output sample. Thanks for support
Hi @ppr ,
$+3.8 M Price (+$0.86M spend delays) , $+1.4 M Other (Low margin) , 0 M Acquisition, $-0.9 M Physical, $-6.5 M Mfg. This is the solution I was expecting. I have kept the 3rd column values under braces, as required. I tried your solution, with slight modifications. It works…
LInqSol.xaml (10.3 KB)
Hey all :slight_smile:
I tried both the solution, both works as expected. You could use @lrtetala one for conventional way and @ppr one for linq way. Thankyou so much both of you for your efforts, it helped a lot. :star2:
