markosc
1
Hi, I have two tables with same and different values in column a. I need to write values from dt2.
Dt1:
Dt2:
Final dt:
arivu96
(Arivazhagan A)
2
Hi @markosc ,
Kindly refer below link, use join data table activity to join the table, you can provide the conditions in join wizard.
Arivu
Srini84
(Srinivas Kadamati)
3
@markosc
You can use Join Datatable activity where you can give the condition as “a” = “a”
Hope this may help you
Thanks
markosc
4
No because with join the result is like this:
Srini84
(Srinivas Kadamati)
5
@markosc
You can check with different join Types, Try with Left and let us know
Thanks
ppr
(Peter Preuss)
6
@markosc
Use a Full Join datatype
Your case is a typical Join scenario. But only use = as operator
About Join types have a look here:
After joining the datata (result: dtJoin DataTable) just remove the unneeded Columns added by the Join activity by
- using a Filter datatable (Col removal configuration)
- dtJoin.DefaultView.ToTable(False, {“a”,“b”,“b_1”})
Rename later b_1 ColName to c by
YourDataTableVar.Columns(“b_1”).ColumnName = “c”
system
(system)
Closed
7
