I am performing click activities on excel sheet based on cursor positions.
To perform the above activity:
1.open Excel application scope
2.Maximize window
3.Click activity using cursor position.
Issue faced: The above workflow is working as expected when executed through UIpath studio but is failing to perform the clicks in the specified positions (cursor position) if executed as a job through Orchestrator.
Note: If I log into the Machine while the orchestrator is running the job, then the click activities click as expected in the specified positions. But if the orchestrator runs in the background the clicks are not happening as expected and the bot clicks in different positions.
I tried using send windows message method but that did not work.
I am suspecting this might be either a resolution issue(the resolution is different if the bot is running in background and hence the clicks are not as per the cursor positions as specified) or Excel Maximization issue(The excel is not maximizing due to which the clicks are not happening on the excel)
Can someone suggest what could be the issue here and any possible fix for this issue.
Thanks in advance.
