Hello Evenryone,
Is there any way to add index column in the datatable and then incrementing row values in added index column by 1,
Input DataTable:
Order Number
Name
City
ID
Order Amount
894626
John
Singapore
STDX-11
₹ 23,121
893610
Kenrick
London
STDX-12
₹ 33,908
893077
Tim
New York
STDX-13
₹ 41,359
892141
Jorge
Amsterdam
STDX-14
₹ 17,352
893143
David
Canada
STDX-15
₹ 39,135
892445
Meena
Thailand
STDX-16
₹ 16,886
891725
Arun
Ireland
STDX-17
₹ 29,960
892142
Alok
Dubai
STDX-18
₹ 42,332
893887
Keshav
San Fransico
STDX-19
₹ 25,061
894805
Amit
California
STDX-20
₹ 29,208
Output required Datatable,
IndexValue
Order Number
Name
City
ID
Order Amount
1
894626
John
Singapore
STDX-11
23121
2
893610
Kenrick
London
STDX-12
33908
3
893077
Tim
New York
STDX-13
41359
4
892141
Jorge
Amsterdam
STDX-14
17352
5
893143
David
Canada
STDX-15
39135
6
892445
Meena
Thailand
STDX-16
16886
7
891725
Arun
Ireland
STDX-17
29960
8
892142
Alok
Dubai
STDX-18
42332
9
893887
Keshav
San Fransico
STDX-19
25061
10
894805
Amit
California
STDX-20
29208
rlgandu
(Rajyalakshmi Gandu)
February 20, 2024, 10:59am
2
@NILESH.BOT369
YourDataTable = YourDataTable.AsEnumerable().Select(Function(row, index) row.ItemArray.Concat({index + 1}).ToArray()).CopyToDataTable()
vrdabberu
(Varunraj Dabberu)
3
HI @NILESH.BOT369
Assign activity:
outputDataTable = (From row In inputDataTable.AsEnumerable()
Let indexValue = inputDataTable.Rows.IndexOf(row) + 1
Let orderAmount = Convert.ToInt32(row("Order Amount").ToString().Replace("₹", "").Trim())
Select outputDataTable.Rows.Add(indexValue, row("Order Number").ToString(), row("Name").ToString(), row("City").ToString(), row("ID").ToString(), orderAmount)).CopyToDataTable()
Regards
@NILESH.BOT369
if you have a build datatable activity having all the columns names
try this once
dt.AsEnumerable().Select(Function(a,i) dt.Clone().LoadDataRow({(i+1).ToString().Concat(a.ItemArray).ToArray()}, False)).CopyToDataTable()
ppr
(Peter Preuss)
February 20, 2024, 11:09am
5
we can avoid the LINQ and achieve it by:
Build DataTable - Configure an empty DataTable with 1 Col - RowNum, Configure AutoIncrement
dtMarked
Then use a Merge DataTable Activity and merge your DataTable into dtMarked
thank you, But what if i dont know how many rows are there in the “dtMarked”?
Because we have to add those many rows in Build Data Table manually?
vrdabberu
(Varunraj Dabberu)
February 20, 2024, 11:15am
7
Hi @NILESH.BOT369
→ Build Data Table
Output-> outputDataTable
→ Read Range Workbook
Output-> dt
→ Use Below syntax in Assign:
outputDataTable = (From row In dt.AsEnumerable()
Let indexValue = dt.Rows.IndexOf(row) + 1
Let orderAmountString = row("Order Amount").ToString().Replace("₹", "").Trim().Replace(",","").Trim()
Let orderAmount As Integer = If(Integer.TryParse(orderAmountString, Nothing), Convert.ToInt32(orderAmountString), 0)
→ Write Range Workbook
Regards
ppr
(Peter Preuss)
February 20, 2024, 11:16am
8
no, you dont have to place any row in dtMarked:
was also mentioned:
when merging dtData into dtMarked the autoincrement will be fired and the rownum is automatically set/ increased
Matt67
(Matthieu LEVAL)
February 20, 2024, 11:23am
9
Hello,
if datas are not already in dataTable, I would go for an auto-increment new column.
If datas are already there, i would stay simple with standard activities, not with linq for this purpose.
Add Data Column for IndexValue
For each row in datatable with currentIndex as output variable.
And Updating currentRow column to CurrentRow(“IndexValue”) with currentIndex
Hope this helps
Got it, thank you,
But, in this case “RowNumber” values will start from 0 when autoincrement will be fired.
ppr
(Peter Preuss)
February 20, 2024, 11:41am
11
we can set the start value by:
Assign Activity:
dtMarked.Columns("RowNum").AutoIncrementSeed = 1
do it before the merge datatable
ppr
(Peter Preuss)
February 20, 2024, 11:57am
13
Thank you for your help, appreciating your help,
But i am marking @vrdabberu 's reply as answer because question was about LINQ and query shared by him works perfectly, Thank you.
Thank you,
Happy Automation!
ppr
(Peter Preuss)
February 20, 2024, 12:49pm
17
NILESH.BOT369:
Ok Perfect
Keep in mind that we do have also the below described discrete approach
Configure the Result Datatable with a Build Datatable (manually or along with the help of dtData.Clone) - dtMarked (NumIndex col at the first position)
Assign Activity:
(From i in Enumerable.Range(0, dtData.Rows.Count)
Let ra1 = dtData.Rows(i).ItemArray
Let ra = ra1.Prepend(i+1).toArray
Select r = dtMarked.Rows.Add(ra)).CopyToDataTable
we avoid the IndexOf and grab by index with this approach
For LINQ learning have a look here
For Column Update Options have a look here:
Hello, thank you so much,
Will try this approach
