"Activity Project Setting" vs "Properties Panel"
Hi all, I just completed the training assessment, and I have a question about the priority between “Activity Project Settings” and the “Properties Panel”? Can anyone help me figure out why my answer is wrong? Thanks.
@LeonJia,
As per my understanding and experience Activity property should take the first priority and then the project.
I don’t have a machine to test this but try to build a simple bot to log these timings and try test it.
If the result is same as we understood, you can raise this with Academy support team here to rectify it.
Thanks,
Ashok :slight_smile:
Hi @ashokkarale ,
The time taken to identify the input box in the ‘Type Into’ activity is variable. It seems that there is no solution to ensure that the time spent on ‘Type Into’ activity remains consistent across each time project executions, making it difficult to determine where the millisecond-level variations come from.
Thank you for the link you provided.
Latest update.
The UiPath team has confirmed this issue and updated ‘400ms’ as the correct answer.
@LeonJia,
That’s great! Kudos to you for highlighting this :v:
Thanks,
