What is thin client automation,thick client automation, surface automation in uipath
@saibinduk - Here are some details. Hope this clarifies.
- Thin client automation - This refers to the automation where the process involves automating the tasks done on a browser. e.g. opening a browser, navigating to an URL, doing some activities on the website (like extracting data) etc.
- Thick client automation - This refers to automating tasks done on a desktop application (for example, SAP GUI).
- Surface automation - This refers to automation of tasks using image recognition, OCR (for example, automating applications hosted on Citrix environment).
Thin client - Automation of an application(windows,web,etc) on server or remote desktop is thin client automation.
Thick client - Automation of any application , if the application is on local system, is thick client automation.
Thank you so much
Thank you so much
FYI - Automation hub Assessments - Applications section does not really define these explicitly. Currently this option is disabled. It would be helpful to have at least a tooltip or description to define these differences.
The terminology is not intuitive to most business users.
thanks, correct response.
Than you so much give clarification about my doubt
