Hello everyone,
I have the following problem : I need to check (using an If statement) if a string variable contains any string value from a List variable. Am I able to do it with the Contains() method? Or is there any method to check?
Thanks a lot!
Hello everyone,
Thanks a lot!
For Each through the list, and check if your string variable contains each value.
myListVar.Any(Function(x) myStringVar.Contains(x))
Thank you!
