How can I get only the values of the fields id , name, country. using regular .net expressions? I hope your support please. Thank you
Hi @Jeanpierren96,
Can you provide the above text mentioned.
Hi, this is the string “Client ID: TD88219\r\nClient Name: Caroll Eisenmann\r\nClient Country: Romania” . Thanks
To extract Client ID
(?<=Client ID: )(.+)(?=\r\nClient Name)
To extract Client Name
(?<=Client Name: )(.+)(?=\r\nClient Country)
To extract Country
(?<=Client Country: )(.+)
If \r\n is part of the string and not newline characters, then you will need to adjust this with a double backslash, so it considers the slash as a character.
(?<=Client ID: )(.+)(?=\\r\\nClient Name)
Yes you are absolutely right, but when i am writing here, it removing the backslash, that’s why i have given the reference to regex101.com
Many thanks to both, they solved my problem. It works with just one for some reason when it comes to comments Clayton gives me null. Thanks for contributing to the community, greetings from Peru. A hug.
Sorry mi english not is very well
Thank very much , a hug. Great Job.
I think it gave you null because the \r\n in your string is a newline character. By adding the double slash, it forces it to look for \r\n as a string rather than a newline character. So, I was just making that suggestion in case it was not a newline character.
Regards.
