System.IO.FileInfo Problem
I have been learning UiPath from UiPath Academy. I am at Switch topic now.
At the same time I am implementing processes according to video however I took an error about variable type as you can see from the picture . How can I handle with it?
Hi @ulas.benakay
Can you try File = New FileInfo(Invoice.ToString()) and let us know if it works?
Best Regards.
I forgot to change “For Each” s TypeArgument from Object to String. When I set this as String, the problem was solved. Thanks a lot
