Hi, I get this error when running a RPA Challenge in Open Browser. Any ideas?
Source: Read Range
Message: The process cannot access the file ‘C:\Users\Lenovo\Dropbox\My PC (LAPTOP-77BDJRKO)\Documents\UiPath\Anchors\challenge.xlsx’ because it is being used by another process.
The error message is pretty clear. You or someone else has that file open. Since it’s in a Dropbox folder it could be that the Dropbox process is using the file.
The file is open in another application or it is open at your end. Close the Excel application before running the automation.
You can also try checking the Antivirus or Backup Services. Try disabling them temporary.
