Problem with Linq query with Group By
Final Edit: In fact the code given by ChatGPT works fine, the problem was further down the loop which processed the v_dtResult datatable and looped over the first row of the table. The real problem was therefore between the chair and the keyboard :slight_smile:
so you can take the code from ChatGPT or from Yoichi, both work
Regards, Olivier
Hi All
I tried to do a linq query by myself but it didn’t work so I asked chatGPT and it gave me something, but the result is not good. Here is the problem:
I have a datatable v_dtData as below (it’s a sample)
I want to group by PR, Order and Amount, then, order by Action Date Descending then by Affection Date descending and copy the first row of the group by in a new datatable
here is the code from ChatGPT:
v_dtResult = v_dtData.AsEnumerable() _
.GroupBy(Function(row) New With { _
Key .PR = row(“PR”).ToString, _
Key .Commande = row(“Order”).ToString,
Key .Montant = convert.ToDouble(row(“Amount”))
}) _
.Select(Function(Group) Group.First()) _
.OrderByDescending(Function(row) row.Field(Of DateTime)(“action date”)) _
.ThenByDescending(Function(row) row.Field(Of DateTime)(“affectation date”)) _
.CopyToDataTable()
the problem is that every row of the v_dtResult are identical, the query only the first group by is processed and repeated until the end. ChatGPT tells me something about class Anonymous and ask me to change for:
Public Class GroupKey
Public Property PR As String
Public Property Commande As String
Public Property Montant As Double
End Class
v_dtResul = v_dtData.AsEnumerable() _
.GroupBy(Function(row) New GroupKey With { _
.PR = row(“PR”).ToString(), _
.Commande = row(“order”).ToString(), _
.Montant = Convert.ToDouble(row(“amount”)) _
}) _
.CopyToDataTable()
but I can’t manage how to implement that in an assign
Can somebody help me ?
@olivier.garcin
Welcome to the Community
Please try this…Change the column names as per your table
dt.AsEnumerable.GroupBy(function(x) {x("PR").ToString,x("Order and Amount").ToString}).Select(function(x) x.OrderByDescending(function(y) Cdate(y("Action Date").ToString)).OrderByDescending(function(y) Cdate(y("Affection Date").ToString)).First).CopyToDataTable
Hope this helps
Hi Anil, thanks for your help
I tried your code with adaptation to real name columns name but the compilation failed
I dont’ know if you notice but Amount (Montant in French) is Double, not String
here is the code I tried to run:
.GroupBy(Function(x) {
x(“PR”).toString,
x(“Commande”).tostring,
x(“Montant”).ToString
}) _
.Select(Function(x) x.OrderByDescending(Function(y) CDate(y(“Date Action”).ToString)).OrderByDescending(Function(y) CDate(y(“Date Affectation”).ToString)).First).CopyToDataTable
Can you try either of the following?
v_dtResult = v_dtData.AsEnumerable.OrderByDescending(Function(r) DateTime.ParseExact(r("Action Date").ToString,"dd/MM/yyyy HH:mm",System.Globalization.CultureInfo.InvariantCulture)).ThenByDescending(Function(r) DateTime.ParseExact(r("Affection Date").ToString,"dd/MM/yyyy",System.Globalization.CultureInfo.InvariantCulture)).GroupBy(Function(r) Tuple.Create(r("PR").ToString,r("Order").ToString,r("Amount").ToString)).Select(Function(g) g.First).CopyToDataTable
OR
v_dtResult = v_dtData.AsEnumerable.OrderByDescending(Function(r) CDate(r("Action Date").ToString)).ThenByDescending(Function(r) CDate(r("Affection Date").ToString)).GroupBy(Function(r) Tuple.Create(r("PR").ToString,r("Order").ToString,r("Amount").ToString)).Select(Function(g) g.First).CopyToDataTable
note: It depends on type (text or date) of date data in worksheet.
@olivier.garcin
Can you show what error you got in compilation?
Hi Yoichi, thanks for your help
I have the same problem with both of your solution, I have a lot of error during compilation. Here is the beginnig of the error compilation message:
An unexpected error occurred during the library compilation process:
Compiling the assembly returned the following errors:
  • Expected ‘End Function’.
  • Expression expected.
  • This statement cannot appear in the method body. It is interpreted as the end of the method
Can you try this in Assign activity as the following?
it’s already what I am doing:
Maybe there is a problem with my version of .NET ?
Can you share your xaml file?
@olivier.garcin
Can you confirm if your is c# or vb.net ?
Also can you share a screenshot of how you are using that might help better…if you can include the exact exception message it could help Or your xaml… because the query given to you is a compiled one in vb.net prject type
I’m a new member so I can’t right now upload file … need to go in 5 topics, read 30 posts. I come back :slight_smile:
Here are my files:
test_Linq.xlsx (12.6 KB)
test_linq.xaml (8.1 KB)
thanks
In my environment, the following expression works.
v_dtDataF =  v_dtData.AsEnumerable.OrderByDescending(Function(r) CDate(r("Action Date").ToString)).ThenByDescending(Function(r) CDate(r("Affectation Date").ToString)).GroupBy(Function(r) Tuple.Create(r("PR").ToString,r("Order").ToString,r("Amount").ToString)).Select(Function(g) g.First).CopyToDataTable
Can you try the following sample?
Sample20230318-2.zip (13.0 KB)
Thanks for your efforts
Unfortunately, I can’t open your Main because my version is 2022.4 and your Main need something more recent :slight_smile:
I copy my test_ling to a brand new Main file and I don’t have any compilation error, and it’s works
I think my original file is broken … My problem seems to be gone, I have to check with a bigger sample
I will let you know :slight_smile:
It works, I selected the last code from Yoichi as Solution, please change that if it’s not correct from your point of vue
Thanks A LOT for your helps Guys, you’re smarter than ChatGPT :smiley:
