One by one, highlight all cells in the Type column on the first page which match the user choice.
I’m not sure exactly what I have to do and maybe that’s why I don’t understand what’s wrong. Actually the terminal doesn’t give me any error but when running the project it does nothing.
I don’t understand your workflow…
why and for what do you use GetAttribute activity?
I have tried to copy it but so much yours and, if I follow your steps in mine, do not work, it crash it.
The one that I had raised doesn’t enter the loop but the terminal but at least doesn’t crash it.
Thank you so much for your time, but I need other options. Thanks!
Totally true, but for some reason the workflow that you have passed me it does crash and mine doesn’t enter the loop For each item in ResultFindChildren, this loop highlight each item from 1st page (taking the desired type into account)
In your workflow, since I don’t quite understand what the GeAattribute activity does, I wouldn’t know how to tell you why it does crash, and in mine I don’t understand why it doesn’t go into the loop…
Thanks for your time and giving me other alternatives.
By debugging and using the Local panel and the Call Stack panel, I was able to see why my workflow, although it didn’t crash, didn’t go into the Loop (ForEach activity).
The reason was, when writing in the InputDialog activity, in the Input Options Array field I wrote the options array (WI1, WI2 and so on) with a blankspace before the string and the web tag don’t have spaces, so it didn’t recognize the string and didn’t enter in the Loop. Once I was corrected this error it has worked perfectly.
