I am trying to run a PowerShell script using the Run power shell script activity from the UiPath.Script.Activities package, but keep receiving this error:
18.4.1+Branch.master.Sha.bc66386dd8e2160b6d35f31d5ce934a5aa4cf4bd
Source: Run power shell script
Message: One or more errors occurred.
Exception Type: System.AggregateException
An ExceptionDetail, likely created by IncludeExceptionDetailInFaults=true, whose value is:
System.AggregateException: One or more errors occurred. ----> System.Management.Automation.ParameterBindingException: A parameter cannot be found that matches parameter name âmsExchMobileAllowedDeviceIDsâ.
at System.Management.Automation.ExceptionHandlingOps.CheckActionPreference(FunctionContext funcContext, Exception exception)
at System.Management.Automation.Interpreter.ActionCallInstruction2.Run(InterpretedFrame frame) at System.Management.Automation.Interpreter.EnterTryCatchFinallyInstruction.Run(InterpretedFrame frame) at System.Management.Automation.Interpreter.EnterTryCatchFinallyInstruction.Run(InterpretedFrame frame) at System.Management.Automation.Interpreter.Interpreter.Run(InterpretedFrame frame) at System.Management.Automation.Interpreter.LightLambda.RunVoid1[T0](T0 arg0) at System.Management.Automation.DlrScriptCommandProcessor.RunClause(Action1 clause, Object dollarUnderbar, Object inputToProcess)
â End of stack trace from previous location where exception was thrown â
at System.Management.Automation.Internal.PipelineProcessor.SynchronousExecuteEnumerate(Object input)
at System.Management.Automation.Runspaces.LocalPipeline.InvokeHelper()
at System.Management.Automation.Runspaces.LocalPipeline.InvokeThreadProc()
â End of inner ExceptionDetail stack trace â
at UiPath.Script.Activities.PowerShell.RunPowerShellScript`1.EndExecute(AsyncCodeActivityContext context, IAsyncResult result)
at System.Activities.AsyncCodeActivity.System.Activities.IAsyncCodeActivity.FinishExecution(AsyncCodeActivityContext context, IAsyncResult result)
at System.Activities.AsyncCodeActivity.CompleteAsyncCodeActivityData.CompleteAsyncCodeActivityWorkItem.Execute(ActivityExecutor executor, BookmarkManager bookmarkManager)
I am able to run another script without an issue and have verified that I have the parameters and Output setup similar. Iâm guessing that it is just having an issue using one of our AD exchange attributesâŚbut the script runs without an issue when I trigger it manually.
Any help would be greatly appreciated.
Cheers!
s3vn
