Please help me with this problem
I am trying to retrieve the Subject of the email in Gmail using IMAP.
in FilterExpression in the properties of IMAP I am using this command “SUBJECT IDs Request” but I got this error:
“The IMAP server replied to the ‘SEARCH’ command and a ‘BAD’ response: Could not parse Command”
Hi @jovarie.inoc
Can you try like this
“(SUBJECT IDs) (SUBJECT Request)”
This will check if subject contain IDs or Request.
cheers
Thank you for your fast response. Is it possible that I can retrieve the specific subject ?. By the way, it is working though and I would like to thank you for that.
the subject name is “IDs Request”.
Thank you again.
@jovarie.inoc
Try with and
same error. and I tried also the OR. The only working is (SUBJECT IDs) (SUBJECT Request). But I need the specific title of the Subject :frowning:
Hi @jovarie.inoc
Try these
"SUBJECT ""IDs Request"""
Or
"SUBJECT 'IDs Request'"
Or
"SUBJECT IDs SUBJECT Request"
I guess bracket is for OR. Been many days used a filter in IMAP
cheers
Thank you so much…
SUBJECT IDs SUBJECT Request this one works
