Hi All,
I want to pass a variable inside Json Body. How Can I do it ? It is throwing error :String Constant must end with double quotes.
Hi All,
@Nikhilesh_Mishra I don’t think it is because of the Variable Since you are using Multiple Lines that causes the error
Does it give you a compiler error after you finished editing?
New line in a string expression shows error but its ok after you have done building your expression.
@Nikhilesh_Mishra Oh yes As @nadim.warsi Said If you just Click Ok even though you have that error it Should be Fine , Wow, That’s Something Useful
