Hello guys,
I’m having some difficulties to find the best activity to automate a task which needs to wait until an element appear/change in a web application, the waiting time may vary; so, searching on the Internet, I found this activity “On Element Appear” which looks that can solve my problem, but it does not work as intended.
This is specifically what I want to do:
1- Click the start button → Done with automation.
2- The start button will start a task, when pressed it will shows a progress bar and a button which you can abort the task. → The automation process will need to wait until the task finished; in this case, I notice that when task finish the button “abort task” change to “reset task”, so I tried to look for the “reset task” button to appear.
3- When the “reset task” button appears, it needs to click that button.
I tried the different combinations settings on the “On Element Appear” activity, but still none of them worked.
Please see images below:
Task running:
Task finished:
Settings 1:
This setting does not work; due to does not wait for the “reset task” to appears, it moves to the next activity which is a click, obviously it fails because of the click timeout and it can not find the “reset task” button.
Setting 2:
This setting successfully waits, it looks like finds the “reset task” button when appears because it marks the button in a red square, but it never moves to the click activity.
- On settings, I changed: RepeatForever: False, WaitActive: True and WaitVisible: True
Hope you guys can help me with this, or if you guys knows a better way to do this.
NOTE: I also tried the “Check App State” activity, but it looks like you have to provide an specific time to wait until do something, but what happen if the waiting time vary? I don’t want to wait all that time until it does something.
Best regards,
Mario
