Need to help to replace column headers in Excel
Hi All,
I’m working on Excel sheet and I’m getting error while working on that.
In my headers i have some special characters because of that I’m unable to read the Excel it is throwing me error.
I’m attaching my input and output sheet. Can anyone guide me.
I want to remove special characters from my headers
Input:
Output:
Hi @Beginner1234
Use Read Range Activity (Output=dataTable)
Use For each Row
The Input Should be dataTable.Columns.Cast(Of DataColumn)()
Use assign activity
col.ColumnName = System.Text.RegularExpressions.Regex.Replace(col.ColumnName, “[^a-zA-Z0-9]”, “”)
Hope this is usefull
@Beginner1234
currentitem=system.text.RegularExpressions.Regex.Replace(currentItem.ToString,“[^a-zA-Z0-9]+”," ")
Sequence1.xaml (8.7 KB)
refer this
@Shiva_Nikhil , @sanjay3 let me try both the solutions.
@Shiva_Nikhil , @sanjay3 After replacing how can I write the entire data in the same sheet
@Beginner1234
use write range workbook activity to write back to excel
@Beginner1234
1.use excel scope activity in that read range activity.-o/p:dt_excel
“it will read even if we have spl. characters in header”
2.create a build data table with column names.-o/p: dt_build
3.assign-
dt_build=dt_excel.AsEnumerable.Select(function(x) dt_build.Clone.LoadDataRow({x(0).ToString,x(1).ToString},false)).CopyToDataTable
4.write range workbook activity,enable add headers in property
Use Write Range Workbook Activity
Thanks @sanjay3 it worked
