Hi can you please answer the below sequence I am really confused about this type of questions can you explain complete concept of queue item processing
You mean to say first filter with deadline the filter with priority>date…
If the date is same in deadline for example 27/3 and 27/3 and both are high priority which one process first
I’m sorry there is mistake this is the correct solution
Among those with Deadline, High priority>Normal>Low regardless of what the deadline is. If same Priority, then sort by earlier deadline.
Then among those without Deadline, sort by higher Priority
in this case we select depend on First In, First Out
The First In will implement in the first and so on
