I have a requirement that when the string starts with 1, I need to replace first letter 1 with Alphabet ‘I’. Can anyone help me with replacing only first letter with another letter. Thanks!
Input - 111IF
Output should be - I11IF
Divya.
Input - 111IF
Divya.
Hey
can you give a try with the following?
strInput.Substring(0,1).Replace("1","I") + strInput.Remove(0,1)
Regards
str_variable = “111IF”
str_variable = If(str_Sample.StartsWith(“1”),str_Sample.Replace(str_Sample(0),“I”),“”)
Pls mark it as solution if it resolves your issue.
How about this Regex expression ?
System.Text.RegularExpressions.Regex.Replace(YourInputString,"^\d","I").Tostring
Regards
Gokul
