Please Help! My bot is logging into the acme site, clicks on work items and then logs out without cycling through the pages
Welcome to the Community.
Please check your variables and arguments are properly assigned.
Moreover if you can share your Xaml file as well. Please send a zip copy to archana.pandit@soprasteria.com
Regards
Archana
I Tried to mail you , but its showing you address in not valid.
try again i miss-spelled my name. Its archana.pandit@soprasteria.com
Hi Anil,
Gone through your Xaml file, the logic you have used is correct.
Some selectors were not appropriate. I have emailed you the correct Xaml file. You can compare it to yours and you will get an idea what you were missing. Moreover please check Set Transaction status Xaml as well i had made some changes in that as mentioned in the walk through. Please mark this as a solution if your query is resolved.
Thanks
Archana
Thabks a lot
